BMW Z4 BONNET OPENING
This seems to be a major problem , taking the car apart to fit new cables. I identified that it was the inboard cable which had stretched , and only by some 10mm.
By moving the outer cable of the inboard cable to the exterior of the junction box that all worked perfectly. It is a shame that there is no adjustment on either of
the cables and which would be possible by redesigning the plastic junction box. with an extended slider such that on original fitting there was the ability to move
the two cable ends closer together as may be required.
