engine slightly misfires. no go at all. what could be the cause? dirty injectors? worn out spark plugs? what areas should i check first before i go to my mechanic just to be sure.
i also hear noise coming from under the car near clutch assembly when left idle . no noise if i press the clutch pedal. is it the releasing bearing that makes the noise?
tia guys!
tia guys!
